주요 콘텐츠로 건너뛰기
소개
Speakers are a common point of failure for the Acer Aspire R7. If your audio sounds distorted, tinny, or isn't playing at all, consider replacing your speakers following this guide. Be very careful not to damage the speaker cable connections when disassembling the device.
부품
지정된 부품이 없습니다.
  1. Acer Aspire R7-572-6423 Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Speakers Replacement: 2 단계, 이미지 1/3 Acer Aspire R7-572-6423 Speakers Replacement: 2 단계, 이미지 2/3 Acer Aspire R7-572-6423 Speakers Replacement: 2 단계, 이미지 3/3
    • Remove the top and middle grips that conceal 3 additional screws.
    • Remove the (8) 10mm T9 screws.
    • Remove the (5) 6mm T9 screws.
  3. Acer Aspire R7-572-6423 Speakers Replacement: 3 단계, 이미지 1/1
    • Remove back panel.
  4. Acer Aspire R7-572-6423 Speakers Replacement: 4 단계, 이미지 1/3 Acer Aspire R7-572-6423 Speakers Replacement: 4 단계, 이미지 2/3 Acer Aspire R7-572-6423 Speakers Replacement: 4 단계, 이미지 3/3
    • Unscrew the (2) 3mm Philips #0 wide head screws.
    • Carefully disconnect the speaker connection.
    • Remove the speaker.
  5. Acer Aspire R7-572-6423 Speakers Replacement: 5 단계, 이미지 1/3 Acer Aspire R7-572-6423 Speakers Replacement: 5 단계, 이미지 2/3 Acer Aspire R7-572-6423 Speakers Replacement: 5 단계, 이미지 3/3
    • Disconnect the speaker from the main board.
결론
Evan Casey
회원 가입일: 2018년 09월 10일
300 평판
안내서 2개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 235
