주요 콘텐츠로 건너뛰기
Acer Aspire R7-572-6423 WiFi Card Replacement
필요한 것
  1. Acer Aspire R7-572-6423 WiFi Card Replacement, WiFi Card: 1 단계, 이미지 1/1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 WiFi Card Replacement: 2 단계, 이미지 1/3 Acer Aspire R7-572-6423 WiFi Card Replacement: 2 단계, 이미지 2/3 Acer Aspire R7-572-6423 WiFi Card Replacement: 2 단계, 이미지 3/3
    • Remove the top and middle grips that conceal 3 additional screws.
    • Remove the 5 6mm T9 screws.
    • Remove the 8 10mm T9 screws.
  3. Acer Aspire R7-572-6423 WiFi Card Replacement: 3 단계, 이미지 1/1
    • Remove back panel.
  4. Acer Aspire R7-572-6423 WiFi Card Replacement: 4 단계, 이미지 1/1
    • Disconnect the wires connecting the card to the motherboard.
  5. Acer Aspire R7-572-6423 WiFi Card Replacement: 5 단계, 이미지 1/2 Acer Aspire R7-572-6423 WiFi Card Replacement: 5 단계, 이미지 2/2
    • Unscrew the 3mm #00 Phillips screw.
    • Remove the WiFi card from the motherboard.
결론
Gavin Hill
회원 가입일: 09/12/18
318 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 291
