이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will walk you through accessing the battery. The battery may need be accessed for replacement or repair. Be careful not to puncture or damage the battery, and dispose of it immediately if it begins to heat up while disconnected.
필요한 것
Remove the 12 5mm Phillips #00 screws.
Use a plastic opening tool to gently pry open the back panel.
Gently lift up the back panel, exposing the internals of the laptop.
다른 2명이 해당 안내서를 완성하였습니다.
