주요 콘텐츠로 건너뛰기
Acer Aspire S3 MS2346 Display Assembly Replacement
필요한 것
  1. Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: 1 단계, 이미지 1/3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: 1 단계, 이미지 2/3 Acer Aspire S3 MS2346 Display Assembly Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: 2 단계, 이미지 1/3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: 2 단계, 이미지 2/3 Acer Aspire S3 MS2346 Display Assembly Replacement, Motherboard: 2 단계, 이미지 3/3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Display Assembly Replacement: 3 단계, 이미지 1/2 Acer Aspire S3 MS2346 Display Assembly Replacement: 3 단계, 이미지 2/2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Display Assembly Replacement: 4 단계, 이미지 1/1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: 5 단계, 이미지 1/2 Acer Aspire S3 MS2346 Display Assembly Replacement, Display Assembly: 5 단계, 이미지 2/2
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Acer Aspire S3 MS2346 Display Assembly Replacement: 6 단계, 이미지 1/1
    • Unlatch the screen from the frame
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nikolas I Steckley
회원 가입일: 09/17/18
666 평판
안내서 5개 작성하였습니다
Washington State, Team S1-G4, Hope Fall 2018 Washington State, Team S1-G4, Hope Fall 2018 회원
WSU-HOPE-F18S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 3개
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - 답글
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
Please arrange me a screen for this acer aspire S3 ms 2346
Amit Gangwar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 3,100
