주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will walk you through disconnecting the display assembly. You may need to remove the display assembly if it is damaged and needs repair, or simply for cleaning.
  1. Remove the 12 5mm Phillips #00 screws. Use a plastic opening tool to gently pry open the back panel. Gently lift up the back panel, exposing the internals of the laptop.
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port. Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port. Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Remove the 5 5mm PH0 screws holding the motherboard in place. Gently remove the motherboard from the chassis.
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Gently remove the motherboard.
    • Gently remove the motherboard.
  5. Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base. Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
    • Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
  6. Unlatch the screen from the frame
    • Unlatch the screen from the frame
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nikolas I Steckley
회원 가입일: 2018년 09월 17일
635 평판
안내서 5개 작성하였습니다
Washington State, Team S1-G4, Hope Fall 2018 Washington State, Team S1-G4, Hope Fall 2018 회원
WSU-HOPE-F18S1G4
3 회원들
안내서 6개 작성하였습니다
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - 답글
You can find this screen on 3rd party sites such as newegg and ebay.
Stacy Schauls -
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 22
30일 전: 80
전체 시간: 1,388
