주요 콘텐츠로 건너뛰기
Acer Aspire S3 MS2346 Keyboard Replacement
필요한 것
  1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: 1 단계, 이미지 1/3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: 1 단계, 이미지 2/3 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: 2 단계, 이미지 1/3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: 2 단계, 이미지 2/3 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: 2 단계, 이미지 3/3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Keyboard Replacement: 3 단계, 이미지 1/2 Acer Aspire S3 MS2346 Keyboard Replacement: 3 단계, 이미지 2/2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Keyboard Replacement: 4 단계, 이미지 1/1
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: 5 단계, 이미지 1/2 Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: 5 단계, 이미지 2/2
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  6. Acer Aspire S3 MS2346 Keyboard Replacement: 6 단계, 이미지 1/1
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  7. Acer Aspire S3 MS2346 Keyboard Replacement, Battery: 7 단계, 이미지 1/1
    • Gently lift the battery from the frame.
  8. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: 8 단계, 이미지 1/3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: 8 단계, 이미지 2/3 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: 8 단계, 이미지 3/3
    • The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
    • You will need to gently pry up the black tape to expose the remaining screws.
  9. Acer Aspire S3 MS2346 Keyboard Replacement: 9 단계, 이미지 1/1
    • Gently lift the board exposing the keyboard assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nikolas I Steckley
회원 가입일: 09/17/18
666 평판
안내서 5개 작성하였습니다
Washington State, Team S1-G4, Hope Fall 2018 Washington State, Team S1-G4, Hope Fall 2018 회원
WSU-HOPE-F18S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,466
