주요 콘텐츠로 건너뛰기
Acer Aspire S3 MS2346 Keyboard Replacement
필요한 것
  1. Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Acer Aspire S3 MS2346 Keyboard Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: 2 단계, 이미지 3개 중 1개 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: 2 단계, 이미지 3개 중 2개 Acer Aspire S3 MS2346 Keyboard Replacement, Motherboard: 2 단계, 이미지 3개 중 3개
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire S3 MS2346 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Gently remove the motherboard.
  5. Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: 5 단계, 이미지 2개 중 1개 Acer Aspire S3 MS2346 Keyboard Replacement, Speakers: 5 단계, 이미지 2개 중 2개
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  6. Acer Aspire S3 MS2346 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  7. Acer Aspire S3 MS2346 Keyboard Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • Gently lift the battery from the frame.
  8. Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: 8 단계, 이미지 3개 중 1개 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: 8 단계, 이미지 3개 중 2개 Acer Aspire S3 MS2346 Keyboard Replacement, Keyboard: 8 단계, 이미지 3개 중 3개
    • The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
    • You will need to gently pry up the black tape to expose the remaining screws.
  9. Acer Aspire S3 MS2346 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift the board exposing the keyboard assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nikolas I Steckley
회원 가입일: 09/17/18
690 평판
안내서 5개를 작성함
Washington State, Team S1-G4, Hope Fall 2018 Washington State, Team S1-G4, Hope Fall 2018 회원
WSU-HOPE-F18S1G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 1,715
