메인 콘텐츠로 스킵하기
소개
This guide will walk you through removing the speakers. The speakers may need to be removed if they are damaged, or just to access the components beneath them.
부품
지정된 부품이 없습니다.
  1. Remove the 12 5mm Phillips #00 screws. Use a plastic opening tool to gently pry open the back panel. Gently lift up the back panel, exposing the internals of the laptop.
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  3. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  4. Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
결론
Nikolas I Steckley
회원 가입일: 2018년 09월 17일
569 평판
안내서 5개 작성하였습니다
Washington State, Team S1-G4, Hope Fall 2018 Washington State, Team S1-G4, Hope Fall 2018 회원
WSU-HOPE-F18S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 71
