주요 콘텐츠로 건너뛰기
Acer Aspire S3-391-6046 Battery Replacement
필요한 것
  1. Acer Aspire S3-391-6046 Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Battery Replacement: 2 단계, 이미지 1/2 Acer Aspire S3-391-6046 Battery Replacement: 2 단계, 이미지 2/2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Battery Replacement: 3 단계, 이미지 1/1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Battery Replacement, Battery: 4 단계, 이미지 1/1
    • With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
  5. Acer Aspire S3-391-6046 Battery Replacement: 5 단계, 이미지 1/2 Acer Aspire S3-391-6046 Battery Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Unplug the three white plugs from their sockets using tweezers by pinching the plugs and pulling them outwards.
    • Pulling with too much force will damage the plugs.
  6. Acer Aspire S3-391-6046 Battery Replacement: 6 단계, 이미지 1/2 Acer Aspire S3-391-6046 Battery Replacement: 6 단계, 이미지 2/2
    • Pull upwards on the plugs located on top of your battery until they have completely come off.
  7. Acer Aspire S3-391-6046 Battery Replacement: 7 단계, 이미지 1/2 Acer Aspire S3-391-6046 Battery Replacement: 7 단계, 이미지 2/2
    • Remove the electrical tape holding down the battery by peeling it upwards.
    • Grab the battery from the bottom and slide it out towards the direction of the bottom of the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brian Rodriguez
회원 가입일: 09/18/18
530 평판
안내서 2개 작성하였습니다
University of North Texas, Team S3-G3, Raign Fall 2018 University of North Texas, Team S3-G3, Raign Fall 2018 회원
UNT-RAIGN-F18S3G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 18
전체 시간: 732
