주요 콘텐츠로 건너뛰기
Acer Aspire S3-391-6046 Fan Replacement
필요한 것
  1. Acer Aspire S3-391-6046 Fan Replacement, Back Cover: 1 단계, 이미지 1/1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Fan Replacement: 2 단계, 이미지 1/2 Acer Aspire S3-391-6046 Fan Replacement: 2 단계, 이미지 2/2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Fan Replacement: 3 단계, 이미지 1/1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Fan Replacement, Fan: 4 단계, 이미지 1/1
    • Unscrew the three screws with a Phillips #0 screwdriver.
  5. Acer Aspire S3-391-6046 Fan Replacement: 5 단계, 이미지 1/1
    • Use either your hands or the tweezers to gently peel back the tape.
  6. Acer Aspire S3-391-6046 Fan Replacement: 6 단계, 이미지 1/2 Acer Aspire S3-391-6046 Fan Replacement: 6 단계, 이미지 2/2
    • Do not pull anything by the wires.
    • Use the tweezers to gently pull the small black plug out.
    • After the plug is out, you should be able to pull the fan assembly out.
결론
Connor Talbot
회원 가입일: 09/20/18
99 평판
안내서 1개 작성함
University of North Texas, Team S3-G3, Raign Fall 2018 University of North Texas, Team S3-G3, Raign Fall 2018 회원
UNT-RAIGN-F18S3G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 18
전체 시간: 573
