주요 콘텐츠로 건너뛰기
Acer Aspire S7-392-6484 Motherboard Replacement
필요한 것
  1. Acer Aspire S7-392-6484 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Acer Aspire S7-392-6484 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Remove all marked 3mm screws from the back panel of the device using a T6 Torx screwdriver.
    • Remove the orange marked screws using a T6 Torx screwdriver. Note that these screws are 4mm in length.
    • After all marked screws have been removed, lift up back panel to expose internal parts.
  2. Acer Aspire S7-392-6484 Motherboard Replacement: 2 단계, 이미지 1/1
    • Unscrew the marked 1.5 mm screws with a Phillips #01 screwdriver.
  3. Acer Aspire S7-392-6484 Motherboard Replacement: 3 단계, 이미지 1/1
    • Disconnect the cable located at the top of the battery. Be careful to pull the cable horizontally, not vertically.
  4. Acer Aspire S7-392-6484 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the battery.
  5. Acer Aspire S7-392-6484 Motherboard Replacement, Fan: 5 단계, 이미지 1/2 Acer Aspire S7-392-6484 Motherboard Replacement, Fan: 5 단계, 이미지 2/2
    • Remove the back panel by unscrewing all marked 3mm screws with a T6 Torx screwdriver.
    • Remove these screws with a T6 Torx screwdriver, but note that these feet screws are 4mm in length.
  6. Acer Aspire S7-392-6484 Motherboard Replacement: 6 단계, 이미지 1/2 Acer Aspire S7-392-6484 Motherboard Replacement: 6 단계, 이미지 2/2
    • Unscrew the marked 2mm screws with a Phillips #01 screwdriver.
    • Remove the fan by disconnecting the marked tabs.
  7. Acer Aspire S7-392-6484 Motherboard Replacement, Solid State Drive: 7 단계, 이미지 1/1
    • Remove the marked 2mm screw with a Phillips #01 screwdriver.
  8. Acer Aspire S7-392-6484 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the hard drive by pulling it away horizontally from its connection.
  9. Acer Aspire S7-392-6484 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/1
    • Remove all marked 2mm screws using a Phillips #1 screwdriver.
    • Disconnect the orange marked connectors.
    • The connectors will take a decent amount of force to disconnect. This will not damage your device, so use the necessary force to disconnect them.
  10. Acer Aspire S7-392-6484 Motherboard Replacement: 10 단계, 이미지 1/1
    • Lift up on the motherboard to pull it out of the casing.
결론
Nicholas Wise
회원 가입일: 02/14/18
754 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G6, Eyestone Spring 2018 USF Tampa, Team S2-G6, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S2G6
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Hi Nicholas.
I was wondering if you really changed yours or just opened it. I need to change now mine and I’m not sure that the new one will be able to read my SSD which is Raid 0 without losing my data… Acer is famous for its stupidity of having a 1 drive Raid 0,
Thanks
Mr Man - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 23
전체 시간: 2,040
