주요 콘텐츠로 건너뛰기
Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement
필요한 것
  1. Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Wedge your plastic opening tool into the crevice on the volume rocker and pull down like a lever to create space.
    • Slide the plastic opening tool along the crevice to separate the back plate.
  2. Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use your screwdriver with the Phillips PH000 attachment to unscrew the single 4mm screw that holds the battery to the base plate.
  3. Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Gently slide the plastic opening tool under the black clip that is attached to the audio ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the tape to expose the left side of the ZIF connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to flip up the black clip on the ZIF connector.
    • Once the black clip is flipped up, it is safe to remove the audio ribbon cable.
  6. Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 6 단계, 이미지 3개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 6 단계, 이미지 3개 중 2개 Acer Aspire Switch 10 SW5-011-18R3 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to gently push the edge of the sliding bundle cable connector out.
    • The smaller bundle cable connector is the only one that needs to be removed.
    • Remove the battery.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Richard Colon
회원 가입일: 09/28/16
492 평판
안내서 2개를 작성함
USF Tampa, Team 3-4, Passmore Fall 2016 USF Tampa, Team 3-4, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G4
4 회원들
안내서 4개를 작성함
3가이드 댓글
But one major part is missing from this description!! The battery.
How much is that?
Marcus - 답글
How can i get a cmos battery off that pc
Kennedy Humphrey - 답글
How does the Switch 10 back removal process differ from the Switch Alpha 12 back removal process. You don’t have much in the stored “fixes” files for the Switch Alpha 12. Can anything here apply to the “12” too? THANKS
danpobrien - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 24
전체 시간: 16,164
