주요 콘텐츠로 건너뛰기
Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement
필요한 것
  1. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • There are four zero insertion force connectors that need to be removed.
    • Use your plastic opening tool to flip up the black clips that secure the ribbon cables to the motherboard.
    • Once the clips are flipped up, the ribbon cables will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Use your plastic opening tool to pry up and lift the antenna cables from the motherboard.
    • The connectors are delicate so use a gentle touch when prying them.
  4. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • To remove the four bundle cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  5. Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Aspire Switch 10 SW5-011-18R3 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Use your screwdriver with the Phillips PH000 attachment to remove the three 4mm screws.
    • Remove the motherboard from the tablet.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Max Francois
회원 가입일: 09/28/16
684 평판
안내서 2개를 작성함
USF Tampa, Team 3-4, Passmore Fall 2016 USF Tampa, Team 3-4, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G4
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 17
전체 시간: 7,825
