주요 콘텐츠로 건너뛰기
Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement
필요한 것
  1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: 1 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: 1 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: 1 단계, 이미지 3/3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 2 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 2 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 2 단계, 이미지 3/3
    • There is one zero insertion force connector that needs to be removed.
    • Use your plastic opening tool to flip up the black clip that secures the ribbon cable to the motherboard.
    • Once the clip is flipped up, the ribbon cable will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 3 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 3 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 3 단계, 이미지 3/3
    • To remove the four bundled cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  4. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 4 단계, 이미지 1/2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to gently pull up the speaker closest to the motherboard.
  5. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 5 단계, 이미지 1/2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 5 단계, 이미지 2/2
    • Remove any tape that may be holding down the speakers or wires in place.
  6. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 6 단계, 이미지 1/2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 6 단계, 이미지 2/2
    • Use tweezers to gently pull up the second speaker.
  7. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: 7 단계, 이미지 1/1
    • Remove and replace the speakers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Richard Colon
회원 가입일: 09/28/16
480 평판
안내서 2개 작성하였습니다
USF Tampa, Team 3-4, Passmore Fall 2016 USF Tampa, Team 3-4, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 14
전체 시간: 1,356
