소개
It's not a common problem, but should your speakers start to malfunction or stop working they'll need to be replaced. This guide will walk you through removing the speakers from the device.
필요한 것
Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
다른 2명이 해당 안내서를 완성하였습니다.
