주요 콘텐츠로 건너뛰기
Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement
필요한 것
  1. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: 1 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: 1 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement, Docking Connectors: 1 단계, 이미지 3/3
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover using the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 2 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 2 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 2 단계, 이미지 3/3
    • Remove the yellow tape from the board cables.
    • Carefully unplug the two board cables from their connectors by pulling on them.
  3. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 3 단계, 이미지 1/2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 3 단계, 이미지 2/2
    • Remove the 2, 4.25 mm screws on the left hand tab that are securing the dock in place.
  4. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 4 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 4 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 4 단계, 이미지 3/3
    • Lift up the metal tab on the left side using the opening tool.
    • Using your fingers may be easier than using the opening tool for this particular step, although both can be used.
  5. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 5 단계, 이미지 1/2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 5 단계, 이미지 2/2
    • Remove the 2, 4.25 mm screws on the right hand tab that are securing the dock in place.
  6. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 6 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 6 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 6 단계, 이미지 3/3
    • Lift the metal tab on the right side up using the opening tool.
  7. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 7 단계, 이미지 1/2 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 7 단계, 이미지 2/2
    • Insert the opening tool between the two sections of the device.
    • Lift up the keyboard section using the opening tool.
  8. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 8 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 8 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 8 단계, 이미지 3/3
    • Carefully pull up on the keyboard section using your hands to remove it from the screen section.
  9. Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 9 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 9 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Docking Connectors Replacement: 9 단계, 이미지 3/3
    • Pull the docking connector off of the screen section.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Grecia Corrada
회원 가입일: 03/19/18
1,134 평판
안내서 6개 작성하였습니다
Baylor, Team S3-G3, Williams Spring 2018 Baylor, Team S3-G3, Williams Spring 2018 회원
BU-WILLIAMS-S18S3G3
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where do you get the docking ports or whatever it is called? With the magnets
Michael - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 29
전체 시간: 2,944
