주요 콘텐츠로 건너뛰기
Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement
필요한 것
  1. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement, Trackpad: 1 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement, Trackpad: 1 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement, Trackpad: 1 단계, 이미지 3/3
    • Remove the 8, 5.25 mm screws on the back cover using the screwdriver.
    • Insert the opening tool into the USB port.
    • Carefully remove the back cover with the opening tool.
  2. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 2 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 2 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 2 단계, 이미지 3/3
    • Lift up on the ZIF connector that secures the ribbon cable using the opening tool.
    • Pull the ribbon cable free.
  3. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 3 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 3 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 3 단계, 이미지 3/3
    • Remove the 4, 2.5 mm screws from the trackpad cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 4 단계, 이미지 1/2 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 4 단계, 이미지 2/2
    • Remove the metal piece that secures the trackpad cover in place using the opening tool.
  5. Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 5 단계, 이미지 1/3 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 5 단계, 이미지 2/3 Acer Aspire Switch 10 SW5-012-18MY Trackpad Replacement: 5 단계, 이미지 3/3
    • Remove the trackpad using the opening tool and your hands.
결론
Grecia Corrada
회원 가입일: 03/19/18
1,134 평판
안내서 6개 작성하였습니다
Baylor, Team S3-G3, Williams Spring 2018 Baylor, Team S3-G3, Williams Spring 2018 회원
BU-WILLIAMS-S18S3G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 830
