소개
If your Acer Aspire TimelineU M5-581T-6807 is not powering on or battery is draining quickly. This guide will show you how to safely change the battery in 6 easy steps.
Before changing the battery make sure the charging port is clean because this can cause the laptop to not receive full power.
Before beginning this repair, power off your computer and unplug from the power source.
필요한 것
Remove the screws, indicated by the circles in the picture, from the back panel using the PH1 attachment.
다른 6명이 해당 안내서를 완성하였습니다.
