주요 콘텐츠로 건너뛰기
Acer Aspire TimelineX 1830T-68U118 RAM Replacement
필요한 것
  1. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: 1 단계, 이미지 1/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: 1 단계, 이미지 2/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: 1 단계, 이미지 3/3
    • Remove the device's battery before beginning.
    • Turn laptop so under side is facing up.
    • Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
  2. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 2 단계, 이미지 1/1
    • Pry open hard drive cover using the Spudger tool.
  3. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 3 단계, 이미지 1/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 3 단계, 이미지 2/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 3 단계, 이미지 3/3
    • Remove screw attached to the hard drive using the PH0 mm Phillips Head.
    • The hard drive can now be removed from the device.
  4. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: 4 단계, 이미지 1/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: 4 단계, 이미지 2/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: 4 단계, 이미지 3/3
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  5. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 5 단계, 이미지 1/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 5 단계, 이미지 2/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 5 단계, 이미지 3/3
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  6. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 6 단계, 이미지 1/2 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  7. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 7 단계, 이미지 1/2 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 7 단계, 이미지 2/2
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  8. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 8 단계, 이미지 1/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 8 단계, 이미지 2/3 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 8 단계, 이미지 3/3
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  9. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, RAM: 9 단계, 이미지 1/1
    • After removing the motherboard, turn it over so that the back side is facing you.
  10. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 10 단계, 이미지 1/1
    • To release the RAM from the motherboard, press both of the metal prongs on the sides of the RAM.
  11. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 11 단계, 이미지 1/1
    • After RAM memory card is released from the motherboard, hold the RAM card on a 45 degree angle and remove the card.
  12. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 12 단계, 이미지 1/1
    • Install your new RAM memory card following these steps in reverse.
결론
Brenna Waterbury
회원 가입일: 09/19/17
523 평판
안내서 5개 작성하였습니다
Idaho State University, Team S4-G6, Watkins Fall 2017 Idaho State University, Team S4-G6, Watkins Fall 2017 회원
ISU-WATKINS-F17S4G6
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Stupid! you can remove the ram after step 2!!!
Erlend - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 558
