주요 콘텐츠로 건너뛰기
Acer Aspire TimelineX 1830T-68U118 RAM Replacement
필요한 것
  1. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: 1 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: 1 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Hard Drive: 1 단계, 이미지 3개 중 3개
    • Remove the device's battery before beginning.
    • Turn laptop so under side is facing up.
    • Locate the hard drive door and unscrew the 5 screws using PH0 mm Phillips Head.
  2. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Pry open hard drive cover using the Spudger tool.
  3. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 3 단계, 이미지 3개 중 3개
    • Remove screw attached to the hard drive using the PH0 mm Phillips Head.
    • The hard drive can now be removed from the device.
  4. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: 4 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: 4 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement, Fan: 4 단계, 이미지 3개 중 3개
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  5. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  6. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  7. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  8. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  9. Acer Aspire TimelineX 1830T-68U118 RAM Replacement, RAM: 9 단계, 이미지 1개 중 1개
    • After removing the motherboard, turn it over so that the back side is facing you.
  10. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 10 단계, 이미지 1개 중 1개
    • To release the RAM from the motherboard, press both of the metal prongs on the sides of the RAM.
  11. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 11 단계, 이미지 1개 중 1개
    • After RAM memory card is released from the motherboard, hold the RAM card on a 45 degree angle and remove the card.
  12. Acer Aspire TimelineX 1830T-68U118 RAM Replacement: 12 단계, 이미지 1개 중 1개
    • Install your new RAM memory card following these steps in reverse.
결론
작성자
4다른 기여자 명과 함께
Brenna Waterbury
회원 가입일: 09/19/17
523 평판
안내서 5개를 작성함
댓글 한 개
Stupid! you can remove the ram after step 2!!!
Erlend - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 27
전체 시간: 627
