주요 콘텐츠로 건너뛰기
Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement
필요한 것
  1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2개 중 2개
    • Place laptop bottom side up, and use a Phillips #1 screwdriver to unscrew the five 8 mm screws from the back panel.
  5. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • After removing the back panel, use a Phillips #1 screwdriver to unscrew the two 8 mm screws that hold the retaining piece to the frame.
  6. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the plastic tab toward the frame to disconnect the hard drive SATA.
  7. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the hard drive from the laptop, and use a Phillips #1 screwdriver to unscrew the two 3 mm screws that secure the retaining piece to the hard drive.
결론
작성자
1다른 기여자 명과 함께
Ian Smiley
회원 가입일: 03/26/19
109 평판
안내서 1개를 작성함
UMass Dartmouth, Team S4-G3, Valliere Spring 2019 UMass Dartmouth, Team S4-G3, Valliere Spring 2019 회원
UMASSD-VALLIERE-S19S4G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 17
전체 시간: 739
