주요 콘텐츠로 건너뛰기
Acer Aspire TimelineX 4820T-6645 RAM Replacement
필요한 것
  1. Acer Aspire TimelineX 4820T-6645 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 RAM Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 4820T-6645 RAM Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 RAM Replacement, RAM: 4 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 4820T-6645 RAM Replacement, RAM: 4 단계, 이미지 2개 중 2개
    • Flip the laptop over and locate the hard drive cover. This is a L shaped plastic cover and has 5 PH#1 8mm screws located around the outside edge. The screw locations are denoted by red circles in the figure.
    • Remove those five screws and then remove the cover.
  5. Acer Aspire TimelineX 4820T-6645 RAM Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 4820T-6645 RAM Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 4820T-6645 RAM Replacement: 5 단계, 이미지 3개 중 3개
    • On either side of the RAM module, there will be two metal tabs. Slide both tabs away from the memory module and the RAM module will pop loose.
    • The location of the tabs are shown by two red circles. Once these tabs are pulled to the side the RAM will pop up. Pulling straight back on the module will remove it.
    • Be careful, these metal tabs may break if you apply too much force to them.
결론
작성자
1다른 기여자 명과 함께
Michael Kilmartin
회원 가입일: 03/26/19
331 평판
안내서 2개를 작성함
UMass Dartmouth, Team S4-G3, Valliere Spring 2019 UMass Dartmouth, Team S4-G3, Valliere Spring 2019 회원
UMASSD-VALLIERE-S19S4G3
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 13
전체 시간: 395
