주요 콘텐츠로 건너뛰기
Acer Aspire TimelineX 4830T-6682 CPU Replacement
필요한 것
  1. Acer Aspire TimelineX 4830T-6682 CPU Replacement, Lower Back Panel: 1 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 4830T-6682 CPU Replacement, Lower Back Panel: 1 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 4830T-6682 CPU Replacement, Lower Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 CPU Replacement, RAM: 2 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 4830T-6682 CPU Replacement, RAM: 2 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 4830T-6682 CPU Replacement, RAM: 2 단계, 이미지 3개 중 3개
    • After the panel has been removed, locate the RAM. It should be on the lower right.
    • There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
  3. Acer Aspire TimelineX 4830T-6682 CPU Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
  4. Acer Aspire TimelineX 4830T-6682 CPU Replacement: 4 단계, 이미지 3개 중 1개 Acer Aspire TimelineX 4830T-6682 CPU Replacement: 4 단계, 이미지 3개 중 2개 Acer Aspire TimelineX 4830T-6682 CPU Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    $3.99
    • Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
    • Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
  5. Acer Aspire TimelineX 4830T-6682 CPU Replacement: 5 단계, 이미지 1개 중 1개
    • Next, disconnect the 4 wired tapes of the keyboard from the motherboard just like we did with the lower front touchpad panel.
  6. Acer Aspire TimelineX 4830T-6682 CPU Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 4830T-6682 CPU Replacement: 6 단계, 이미지 2개 중 2개
    • Finally, using an opening tool, gently pry along the edge of the keyboard to separate it from the laptop.
  7. Acer Aspire TimelineX 4830T-6682 CPU Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • The battery will be on the side closest to the screen.
    • Gently lift it out. It will still be attached by white, red, and black wires.
  8. Acer Aspire TimelineX 4830T-6682 CPU Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire TimelineX 4830T-6682 CPU Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the white plug, it should easily detach.
    • Remove the battery from the device.
  9. Acer Aspire TimelineX 4830T-6682 CPU Replacement, CPU: 9 단계, 이미지 1개 중 1개
    • Turn the CPU screw counterclockwise 180 degrees with a Flathead 2.5mm screwdriver
  10. Acer Aspire TimelineX 4830T-6682 CPU Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the CPU vertically from the socket being careful not to bend the CPU pins
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jon Brunsell
회원 가입일: 07/10/19
592 평판
안내서 6개를 작성함
3가이드 댓글
Followed instructions computer now dosnt turn on
Ian Burgess - 답글
Hello Ian,
If you would like me to help troubleshoot your computer, please provide more details by answering the following questions?
Jon Brunsell - 답글
Was the computer booting before following the CPU replacement instructions?
What troubleshooting was completed to determine the CPU had to be replaced?
Was the CPU replacement part verified as working before installation?
Is the computer powering up to any screen, showing partial boot?
Jon Brunsell - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 40
전체 시간: 1,050
