소개
In this guide you will learn how to disassemble your laptop, remove the battery and replace it.
필요한 것
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Yes don’t need to take cover off -battery can be removed by using a pen/screwdriver to slide the tab to the side & battery releases.
It has a very small image of an arrow with a pen next to it. Very misleading (I tried to push it in first!)
If you wiggle the battery, you can see the battery release tab moves with it :-)
