주요 콘텐츠로 건너뛰기
Acer Aspire V3-551-8469 Fan Replacement
필요한 것
  1. Acer Aspire V3-551-8469 Fan Replacement, Fan: 1 단계, 이미지 1/2 Acer Aspire V3-551-8469 Fan Replacement, Fan: 1 단계, 이미지 2/2
    • To release the battery, slide the orange tab to the right with a spudger.
    • The battery is now released and can be picked up and set to the side.
  2. Acer Aspire V3-551-8469 Fan Replacement: 2 단계, 이미지 1/3 Acer Aspire V3-551-8469 Fan Replacement: 2 단계, 이미지 2/3 Acer Aspire V3-551-8469 Fan Replacement: 2 단계, 이미지 3/3
    • Remove the 16 5.3 mm Phillips #0 screws.
    • Remove the three 3 mm Phillips #00 screws.
  3. Acer Aspire V3-551-8469 Fan Replacement: 3 단계, 이미지 1/3 Acer Aspire V3-551-8469 Fan Replacement: 3 단계, 이미지 2/3 Acer Aspire V3-551-8469 Fan Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the back panel, and remove the white cable from the wifi chip using a pair of tweezers.
  4. Acer Aspire V3-551-8469 Fan Replacement: 4 단계, 이미지 1/1
    • Using a Phillips head #0 screwdriver, remove the four 5.3 mm screws.
  5. Acer Aspire V3-551-8469 Fan Replacement: 5 단계, 이미지 1/3 Acer Aspire V3-551-8469 Fan Replacement: 5 단계, 이미지 2/3 Acer Aspire V3-551-8469 Fan Replacement: 5 단계, 이미지 3/3
    • Flip the computer over and remove the touchpad cover and keyboard.
    • Be careful doing this since there are two ribbon cables connecting both panels to the motherboard.
  6. Acer Aspire V3-551-8469 Fan Replacement: 6 단계, 이미지 1/2 Acer Aspire V3-551-8469 Fan Replacement: 6 단계, 이미지 2/2
    • Disconnect the four ribbon cables.
  7. Acer Aspire V3-551-8469 Fan Replacement: 7 단계, 이미지 1/1
    • Remove the five 5.3 mm Phillips #0 screws.
  8. Acer Aspire V3-551-8469 Fan Replacement: 8 단계, 이미지 1/1
    • Gently lift up the motherboard and slide it out to the right.
    • Do not force the board. If stuck, check that the ports on the left are loose, that no wires are still attached, and no screws are still in.
  9. Acer Aspire V3-551-8469 Fan Replacement: 9 단계, 이미지 1/1
    • Flip the motherboard over and using a pair of tweezers, remove the cable.
  10. Acer Aspire V3-551-8469 Fan Replacement: 10 단계, 이미지 1/2 Acer Aspire V3-551-8469 Fan Replacement: 10 단계, 이미지 2/2
    • Remove the six 2mm Phillips #00 screws.
  11. Acer Aspire V3-551-8469 Fan Replacement: 11 단계, 이미지 1/1
    • Using a pair of tweezers, remove the cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maritsa Garcia
회원 가입일: 10/22/18
800 평판
안내서 5개 작성하였습니다
Baylor, Team S1-G4, Williams Fall 2018 Baylor, Team S1-G4, Williams Fall 2018 회원
BU-WILLIAMS-F18S1G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 599
