소개
The fan in a laptop keeps the device from overheating. If your device is experiencing this common symptom, it's time to replace the fan. Use this guide to replace broken fans in the Acer Aspire V3-551-8469. No complicated manipulation is required, but there are a lot of screws that need to be removed; therefore, be sure to keep track which screw goes where.
필요한 것
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
