소개
Removing the back panel gives access to most everything else in the laptop.
필요한 것
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
danwat1234 - 답글
