주요 콘텐츠로 건너뛰기
Acer Aspire V3-551-8887 Keyboard Replacement
필요한 것
  1. Acer Aspire V3-551-8887 Keyboard Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Keyboard Replacement, USB Ports: 3 단계, 이미지 1개 중 1개
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Keyboard Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Keyboard Replacement, Keyboard: 10 단계, 이미지 1개 중 1개
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Keyboard Replacement: 11 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Keyboard Replacement: 11 단계, 이미지 2개 중 2개
    • Use a spudger to gently lift the keyboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Alexander Lazar
회원 가입일: 04/22/14
357 평판
안내서 2개를 작성함
Cal Poly, Team 8-8, Regan Spring 2014 Cal Poly, Team 8-8, Regan Spring 2014 회원
CPSU-REGAN-S14S8G8
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 20
지난 30일: 39
전체 시간: 6,795
