주요 콘텐츠로 건너뛰기
Acer Aspire V3-551-8887 Motherboard Replacement
필요한 것
  1. Acer Aspire V3-551-8887 Motherboard Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Motherboard Replacement, USB Ports: 3 단계, 이미지 1개 중 1개
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Motherboard Replacement, Keyboard: 10 단계, 이미지 1개 중 1개
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Acer Aspire V3-551-8887 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Use a spudger to gently lift the keyboard.
  12. Acer Aspire V3-551-8887 Motherboard Replacement, Motherboard: 12 단계, 이미지 1개 중 1개
    • Remove the two 10 mm Phillips #1 screws connecting the motherboard to the case.
  13. Acer Aspire V3-551-8887 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Disconnect the 4 ribbon cables connected to the motherboard.
    • Some ribbon cable connections may not be accessible until after beginning to lift.
  14. Acer Aspire V3-551-8887 Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Very carefully lift the motherboard.
    • Do not force the board. If stuck, check that the ports on the left are not stuck, that no wires are still attached, and no screws are still in.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Alexander Lazar
회원 가입일: 04/22/14
357 평판
안내서 2개를 작성함
Cal Poly, Team 8-8, Regan Spring 2014 Cal Poly, Team 8-8, Regan Spring 2014 회원
CPSU-REGAN-S14S8G8
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 5,388
