주요 콘텐츠로 건너뛰기
Acer Aspire V3-771G Hard Drive Replacement
필요한 것
  1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Shut down the laptop.
    • Remove the power charging cord from the laptop.
  2. Acer Aspire V3-771G Hard Drive Replacement: 2 단계, 이미지 1/3 Acer Aspire V3-771G Hard Drive Replacement: 2 단계, 이미지 2/3 Acer Aspire V3-771G Hard Drive Replacement: 2 단계, 이미지 3/3
    • Flip the laptop over, and find the battery compartment.
    • Use your fingers to move the orange slider located just below the battery compartment to the right.
    • Do not touch the battery connectors on the battery or laptop.
    • Lift the battery up and remove from the compartment.
  3. Acer Aspire V3-771G Hard Drive Replacement: 3 단계, 이미지 1/2 Acer Aspire V3-771G Hard Drive Replacement: 3 단계, 이미지 2/2
    • Using the screwdriver, remove the nine 8 mm screws from the panel on the back of the laptop.
    • Gently lift the panel up from the open slot, use the opening tools as necessary, to free the panel from the laptop.
  4. Acer Aspire V3-771G Hard Drive Replacement: 4 단계, 이미지 1/2 Acer Aspire V3-771G Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove the two screws holding the hard drive sled in place.
    • While grounding yourself, gently pull the black tag straight back, not up, to free the hard drive.
  5. Acer Aspire V3-771G Hard Drive Replacement: 5 단계, 이미지 1/3 Acer Aspire V3-771G Hard Drive Replacement: 5 단계, 이미지 2/3 Acer Aspire V3-771G Hard Drive Replacement: 5 단계, 이미지 3/3
    • Using the screwdriver, remove the four 4 mm screws from the hard drive sled.
    • Carefully remove the hard drive. A new one may now be installed.
결론
다른 9명이 해당 안내서를 완성하였습니다.
David Walker
회원 가입일: 10/11/14
341 평판
안내서 1개 작성함
USF Tampa, Team 1-36, Donnelly Fall 2014 USF Tampa, Team 1-36, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G36
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Please pardon my inquiry. Is the same replacement can be done to Acer Aspire V3-572P-540V? Any reply will be appreciated.
b6789b - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 30
전체 시간: 13,631
