주요 콘텐츠로 건너뛰기
Acer Aspire V5-122P-0468 Touchpad Replacement
필요한 것
  1. Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: 1 단계, 이미지 1/2 Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Touchpad Replacement: 2 단계, 이미지 1/2 Acer Aspire V5-122P-0468 Touchpad Replacement: 2 단계, 이미지 2/2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Touchpad Replacement: 3 단계, 이미지 1/2 Acer Aspire V5-122P-0468 Touchpad Replacement: 3 단계, 이미지 2/2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Touchpad Replacement: 4 단계, 이미지 1/3 Acer Aspire V5-122P-0468 Touchpad Replacement: 4 단계, 이미지 2/3 Acer Aspire V5-122P-0468 Touchpad Replacement: 4 단계, 이미지 3/3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Touchpad Replacement: 5 단계, 이미지 1/3 Acer Aspire V5-122P-0468 Touchpad Replacement: 5 단계, 이미지 2/3 Acer Aspire V5-122P-0468 Touchpad Replacement: 5 단계, 이미지 3/3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Touchpad Replacement, Touchpad: 6 단계, 이미지 1/1
    • Use the spudger to pop up the latch on the ZIF connector.
    • Pull out the ribbon cable.
  7. Acer Aspire V5-122P-0468 Touchpad Replacement: 7 단계, 이미지 1/3 Acer Aspire V5-122P-0468 Touchpad Replacement: 7 단계, 이미지 2/3 Acer Aspire V5-122P-0468 Touchpad Replacement: 7 단계, 이미지 3/3
    • Remove the three 2mm PH #0 screws.
    • Lift the metal tape up and off of the mounting bracket.
  8. Acer Aspire V5-122P-0468 Touchpad Replacement: 8 단계, 이미지 1/1
    • Remove the metal mounting bracket from the bottom of the touchpad
  9. Acer Aspire V5-122P-0468 Touchpad Replacement: 9 단계, 이미지 1/2 Acer Aspire V5-122P-0468 Touchpad Replacement: 9 단계, 이미지 2/2
    • Carefully remove the foam pad from along the top edge of touchpad using a spudger.
    • This pad can be reused.
    • Remove the four 2mm PH #0 screws.
  10. Acer Aspire V5-122P-0468 Touchpad Replacement: 10 단계, 이미지 1/1
    • Remove the touchpad from the laptop using a spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nat McCormick
회원 가입일: 02/15/18
801 평판
안내서 5개 작성하였습니다
USF Tampa, Team S16-G1, Boczar Spring 2018 USF Tampa, Team S16-G1, Boczar Spring 2018 회원
USFT-BOCZAR-S18S16G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 28
전체 시간: 1,674
