소개
The touchpad can become unresponsive or just break all together. This guide will show how to safely remove and replace the touchpad in your Acer Aspire laptop.
필요한 것
Remove the nine 4mm screws with a PH0 screwdriver.
Remove the two 6mm screws with a PH0 screwdriver.
Use the spudger to pop up the latch on the ZIF connector.
Pull out the ribbon cable.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
