주요 콘텐츠로 건너뛰기
Acer Aspire V5-122P-0889 Battery Replacement
필요한 것
동영상 개요
  1. Acer Aspire V5-122P-0889 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0889 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
    • Remove the remaining 9 visible screws, which are 5mm in length.
    • Every screw in this laptop can be removed with a Phillips #0 screwdriver.
  2. Acer Aspire V5-122P-0889 Battery Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0889 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Towards the top right corner of the laptop, there is a rubber piece covering the final screw holding the cover on, as well as a set of pins. Use your fingernail to remove this piece of rubber, and then unscrew the hidden 5mm screw.
  3. Acer Aspire V5-122P-0889 Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0889 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Going around the edges of the laptop, apply light to moderate amounts of pressure away from the laptop to unseat the cover so that it can be removed. Once you have removed the cover, place it face-up in a safe place to avoid getting the inside of the cover dirty.
    • If you are having trouble unseating the cover by hand, a nylon spudger can be run around the perimeter of the laptop to help lift the cover away from the case.
  4. Acer Aspire V5-122P-0889 Battery Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0889 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully unscrew the two 5mm screws holding the battery in place.
  5. Acer Aspire V5-122P-0889 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully use light upward pressure to unseat the battery from the case, but do not pull on the cord or try and completely remove the battery from the case.
  6. Acer Aspire V5-122P-0889 Battery Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire V5-122P-0889 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Finally, disconnect the battery from the motherboard by undoing the power connector. To undo the connector, simply apply light to moderate pull on the sides of the connector.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Katelynn couto
회원 가입일: 03/07/16
705 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-1, Landers Spring 2016 UMass Dartmouth, Team 5-1, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G1
3 회원들
안내서 10개를 작성함
3가이드 댓글
Flawless! the harness on the replacement was a little long and lumpy, but the back went back on just fine.
adhansonx - 답글
I just can't get one of the screws out - by the sd card slot. Any suggestions?
Any good sources for the replacement battery?
Chris - 답글
Nice guide. Thanks. I have the same model. May I know if it’s normal for my laptop not to work if the battery is removed? I removed the battery pack because they are bulging and not charging anymore. Since it will still take me a long time to buy a replacement and I already have many works pending, can you help me make it work with just the adapter plugged in? I badly need to finish my projects.
Jerry Pulido - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 79
전체 시간: 11,817
