주요 콘텐츠로 건너뛰기
Acer Aspire V5-122P-0889 CPU fan Replacement
필요한 것
  1. Acer Aspire V5-122P-0889 CPU fan Replacement, Battery: 1 단계, 이미지 1/2 Acer Aspire V5-122P-0889 CPU fan Replacement, Battery: 1 단계, 이미지 2/2
    • Start the process of removing the bottom cover of the laptop by unscrewing the 8mm screws in the top right and left corners.
    • Remove the remaining 9 visible screws, which are 5mm in length.
    • Every screw in this laptop can be removed with a Phillips #0 screwdriver.
  2. Acer Aspire V5-122P-0889 CPU fan Replacement: 2 단계, 이미지 1/2 Acer Aspire V5-122P-0889 CPU fan Replacement: 2 단계, 이미지 2/2
    • Towards the top right corner of the laptop, there is a rubber piece covering the final screw holding the cover on, as well as a set of pins. Use your fingernail to remove this piece of rubber, and then unscrew the hidden 5mm screw.
  3. Acer Aspire V5-122P-0889 CPU fan Replacement: 3 단계, 이미지 1/2 Acer Aspire V5-122P-0889 CPU fan Replacement: 3 단계, 이미지 2/2
    • Going around the edges of the laptop, apply light to moderate amounts of pressure away from the laptop to unseat the cover so that it can be removed. Once you have removed the cover, place it face-up in a safe place to avoid getting the inside of the cover dirty.
    • If you are having trouble unseating the cover by hand, a nylon spudger can be run around the perimeter of the laptop to help lift the cover away from the case.
  4. Acer Aspire V5-122P-0889 CPU fan Replacement: 4 단계, 이미지 1/2 Acer Aspire V5-122P-0889 CPU fan Replacement: 4 단계, 이미지 2/2
    • Carefully unscrew the two 5mm screws holding the battery in place.
  5. Acer Aspire V5-122P-0889 CPU fan Replacement: 5 단계, 이미지 1/1
    • Carefully use light upward pressure to unseat the battery from the case, but do not pull on the cord or try and completely remove the battery from the case.
  6. Acer Aspire V5-122P-0889 CPU fan Replacement: 6 단계, 이미지 1/2 Acer Aspire V5-122P-0889 CPU fan Replacement: 6 단계, 이미지 2/2
    • Finally, disconnect the battery from the motherboard by undoing the power connector. To undo the connector, simply apply light to moderate pull on the sides of the connector.
  7. Acer Aspire V5-122P-0889 CPU fan Replacement, CPU fan: 7 단계, 이미지 1/2 Acer Aspire V5-122P-0889 CPU fan Replacement, CPU fan: 7 단계, 이미지 2/2
    • Remove the three screws that hold the fan into place.
    • Two of the screws remain attached to the metal heat-sink part of the fan after being unscrewed. This is normal, as they are build into the heat-sink.
  8. Acer Aspire V5-122P-0889 CPU fan Replacement: 8 단계, 이미지 1/1
    • Disconnect the power cable that connects the fan to the motherboard.
  9. Acer Aspire V5-122P-0889 CPU fan Replacement: 9 단계, 이미지 1/1
    • Remove the CPU fan from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katelynn couto
회원 가입일: 03/07/16
693 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-1, Landers Spring 2016 UMass Dartmouth, Team 5-1, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 18
전체 시간: 1,408
