주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2629 Hard Drive Replacement
필요한 것
  1. Acer Aspire V5-131-2629 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Hard Drive Replacement, Cover: 5 단계, 이미지 1개 중 1개
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1개 중 1개
    • Locate the large blue hard drive on the left side on the computer.
  8. Acer Aspire V5-131-2629 Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Gently pull out the ribbon cable on the computer-attached end.
  9. Acer Aspire V5-131-2629 Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Completely remove the hard drive from the hard drive bay.
  10. Acer Aspire V5-131-2629 Hard Drive Replacement: 10 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Hard Drive Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the two screws on the side of the hard drive cage.
  11. Acer Aspire V5-131-2629 Hard Drive Replacement: 11 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Hard Drive Replacement: 11 단계, 이미지 2개 중 2개
    • Pull the hard drive cage from the hard drive to separate the two.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Nicole B Bosse
회원 가입일: 10/27/19
175 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G3
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 18
전체 시간: 1,625
