주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2629 Screen Replacement
필요한 것
  1. Acer Aspire V5-131-2629 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Screen Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Screen Replacement, Cover: 5 단계, 이미지 1개 중 1개
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Screen Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Screen Replacement, Screen: 7 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Screen Replacement, Screen: 7 단계, 이미지 2개 중 2개
    • Remove the screen bezel by lifting up the inside rim of the bezel and popping the edge out in steady upwards and outwards motions.
    • Complete this motion around the entire circumference of the bezel.
  8. Acer Aspire V5-131-2629 Screen Replacement: 8 단계, 이미지 3개 중 1개 Acer Aspire V5-131-2629 Screen Replacement: 8 단계, 이미지 3개 중 2개 Acer Aspire V5-131-2629 Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the four Phillips screws from each of the mounting tabs in the corners of the screen.
  9. Acer Aspire V5-131-2629 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Peel back the adhesive tape that runs the length of the bottom of the screen.
    • Be careful not to damage the cables which run between the tape and the screen.
  10. Acer Aspire V5-131-2629 Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Using the mounting tabs at the top corners of the screen, gently lift the screen up and out and lay it flat on the keyboard.
  11. Acer Aspire V5-131-2629 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the adhesive tape covering the gold-colored connector on the top left corner of the screen.
결론
작성자
4다른 기여자 명과 함께
Aaron Almeida
회원 가입일: 10/25/19
551 평판
안내서 4개를 작성함
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G3
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 677
