주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2629 Wireless Adapter Replacement
필요한 것
  1. Acer Aspire V5-131-2629 Wireless Adapter Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Wireless Adapter Replacement: 2 단계, 이미지 1개 중 1개
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Wireless Adapter Replacement: 3 단계, 이미지 1개 중 1개
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Wireless Adapter Replacement: 4 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Wireless Adapter Replacement: 4 단계, 이미지 2개 중 2개
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Wireless Adapter Replacement, Cover: 5 단계, 이미지 1개 중 1개
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Wireless Adapter Replacement: 6 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Wireless Adapter Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Wireless Adapter Replacement, Wireless Adapter: 7 단계, 이미지 1개 중 1개
    • Remove the black and white cables that are attached to the Wi-Fi card.
  8. Acer Aspire V5-131-2629 Wireless Adapter Replacement: 8 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2629 Wireless Adapter Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the single Phillips screw securing the Wi-Fi card.
    • The wireless adapter will pop out at a 45 degree angle.
  9. Acer Aspire V5-131-2629 Wireless Adapter Replacement: 9 단계, 이미지 1개 중 1개
    • Pull on the wireless adapter to remove it and replace it.
결론
작성자
3다른 기여자 명과 함께
Aaron Almeida
회원 가입일: 10/25/19
551 평판
안내서 4개를 작성함
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G3
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 857
