주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2680 Battery Replacement
필요한 것
  1. Acer Aspire V5-131-2680 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Battery Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2680 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2680 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • In front of the battery, you will find a sliding flap. This is a battery-release lock.
    • Place your finger on the latch and slide the latch to open. Pull out the battery from its compartment.
    • Do not remove your finger from the latch while sliding the battery out.
    • Once the battery is out, release the latch.
결론
작성자
1다른 기여자 명과 함께
Naomi Zaldana
회원 가입일: 09/26/22
147 평판
안내서 1개를 작성함
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 269
