주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2680 Hard Drive Replacement
  1. Acer Aspire V5-131-2680 Hard Drive Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2680 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2680 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 2개
    • On the sides of the hard drive, you will see two side tabs. This is what holds the hard drive in place.
    • Place your finger on the left tab and press on it to loosen the hard drive.
    • After the hard drive is loose, slide it out of the compartment.
    • Do not remove your finger from the side tab while removing the hard drive.
  4. Acer Aspire V5-131-2680 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • You have successfully removed the hard drive from the laptop.
결론
작성자
3다른 기여자 명과 함께
Mauricio Moreno
회원 가입일: 09/26/22
601 평판
안내서 5개를 작성함
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 212
