주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2680 Motherboard Replacement
필요한 것
  1. Acer Aspire V5-131-2680 Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Turn the Acer Aspire upside down, with the stickers facing up.
    • Unplug the charger and make sure the device is off.
  2. Acer Aspire V5-131-2680 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the twenty M2 x 6 screws using a Phillips #00 screwdriver.
    • Unplug the battery and disconnect all the components connected to the motherboard.
    • Pry open the bottom of the laptop using the opening tool.
  3. Acer Aspire V5-131-2680 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-131-2680 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-131-2680 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Disconnect the two components that are attached to the motherboard and keyboard.
    • The large ribbon cable is disconnected by pulling apart the two white tabs found on each side of the connection and lifting the cable out.
    • The small wire can be removed by simply pulling on the blue tape
  4. Acer Aspire V5-131-2680 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the three M2 x 3 Phillips screws on the motherboard.
  5. Acer Aspire V5-131-2680 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire V5-131-2680 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire V5-131-2680 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Disconnect all the big and small wires connected to the motherboard.
    • The big wires must be squeezed on each side of the connection to release the tabs, then pull the cable out.
    • The small wires can be removed simply by pulling the cable out of the connection
  6. Acer Aspire V5-131-2680 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull the motherboard up and to the right at the same time.
  7. Acer Aspire V5-131-2680 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Once the motherboard is out, take off the tape that is holding the fan and the motherboard together. Push the fan down and it will come off.
결론
작성자
6다른 기여자 명과 함께
Mauricio Moreno
회원 가입일: 09/26/22
601 평판
안내서 5개를 작성함
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 324
