주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2680 Screen Replacement
필요한 것
  1. Acer Aspire V5-131-2680 Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Open up your laptop.
    • Place an opening tool in the crack between the screen and the back compartment. Drag the opening tool throughout the crack to open.
    • Remove the front black frame of the laptop.
  2. Acer Aspire V5-131-2680 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use a JIS #1 screwdriver to remove the 10 marked M2 x 3 Phillips screws.
    • Use a magnetic bit to fully remove the screws from their locations.
  3. Acer Aspire V5-131-2680 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove then aluminum frame holding the screen in place.
    • This frame may have some sharp edges. Lift and remove slowly.
  4. Acer Aspire V5-131-2680 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully peel off the tape surrounding the screen.
  5. Acer Aspire V5-131-2680 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Unplug the pin conector from the display.
    • This is a sensitive piece. Do not grab harshly or the pin can break.
    • The screen is now free to be removed.
결론
작성자
3다른 기여자 명과 함께
Mauricio Moreno
회원 가입일: 09/26/22
601 평판
안내서 5개를 작성함
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 151
