소개
If you need to replace the touchpad on your Acer Aspire V5 and you have already considered other solutions, then this guide will help you.
Some potential problems may include the touchpad being disabled or the touchpad driver being outdated or missing. To ensure that you are not experiencing any of these problems, check out our troubleshooting guide for an unresponsive touchpad.
If you want to replace your touchpad because it's damaged, then continue with this replacement guide! You will need an opening tool, a precision bit driver, and a magnetic pickup bit.
Before beginning, make sure to close your laptop, power it off completely, and disconnect it from any external power source.
필요한 것
Remove the twenty 6 mm screws using a Phillips #00 screwdriver.
Unplug the battery and disconnect all the components connected to the motherboard.
Pry open the bottom of the laptop using the pry tool.
