주요 콘텐츠로 건너뛰기
Acer Aspire V5-131-2680 Touchpad Replacement
필요한 것
  1. Acer Aspire V5-131-2680 Touchpad Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Touchpad Replacement: 2 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2680 Touchpad Replacement: 2 단계, 이미지 2개 중 2개
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Touchpad Replacement, Touchpad: 3 단계, 이미지 1개 중 1개
    • Remove the twenty 6 mm screws using a Phillips #00 screwdriver.
    • Unplug the battery and disconnect all the components connected to the motherboard.
    • Pry open the bottom of the laptop using the pry tool.
  4. Acer Aspire V5-131-2680 Touchpad Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the larger ribbon cable that connects from the motherboard to the keyboard by gently pulling on the end that attaches to the keyboard.
  5. Acer Aspire V5-131-2680 Touchpad Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the tape that is holding the smaller ribbon to the touchpad. Gently disconnect the smaller ribbon by pulling on it.
  6. Acer Aspire V5-131-2680 Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • Once both of the ribbons are disconnected, the side with the keyboard will detach from the rest of the computer.
    • Now we can move the keyboard side without the rest of the laptop.
  7. Acer Aspire V5-131-2680 Touchpad Replacement: 7 단계, 이미지 1개 중 1개
    • Remove all of the M2 x 3 Phillips screws that are holding the keyboard in place.
    • Some screws will be located under a piece of tape. Remove the tape prior to unscrewing these screws.
  8. Acer Aspire V5-131-2680 Touchpad Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the keyboard from the frame by pulling up on the keyboard.
    • With the keyboard out of the way, we will be able to access the touchpad.
  9. Acer Aspire V5-131-2680 Touchpad Replacement: 9 단계, 이미지 2개 중 1개 Acer Aspire V5-131-2680 Touchpad Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the touchpad from the frame by pushing up on the touchpad.
결론
작성자
4다른 기여자 명과 함께
Mauricio Moreno
회원 가입일: 09/26/22
601 평판
안내서 5개를 작성함
CSU Los Angeles, Team 6-1, Adachi Fall 2022 CSU Los Angeles, Team 6-1, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G1
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 222
