주요 콘텐츠로 건너뛰기
Acer Aspire V5-473P-5602 Fan Replacement
필요한 것
  1. Acer Aspire V5-473P-5602 Fan Replacement, Back Panel: 1 단계, 이미지 1/2 Acer Aspire V5-473P-5602 Fan Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Fan Replacement, Battery: 2 단계, 이미지 1/2 Acer Aspire V5-473P-5602 Fan Replacement, Battery: 2 단계, 이미지 2/2
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Fan Replacement: 3 단계, 이미지 1/1
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Fan Replacement: 4 단계, 이미지 1/1
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Fan Replacement, Fan: 5 단계, 이미지 1/2 Acer Aspire V5-473P-5602 Fan Replacement, Fan: 5 단계, 이미지 2/2
    • Remove the five Phillips #0 screws that are holding the fan down to the base.
  6. Acer Aspire V5-473P-5602 Fan Replacement: 6 단계, 이미지 1/2 Acer Aspire V5-473P-5602 Fan Replacement: 6 단계, 이미지 2/2
    • Gently unplug the cables from the Wi-Fi card.
  7. Acer Aspire V5-473P-5602 Fan Replacement: 7 단계, 이미지 1/1
    • Remove the fan from the laptop.
결론
Javairia Fatima
회원 가입일: 01/22/20
100 평판
안내서 1개 작성함
York University, Team S8-G6, Turner Winter 2020 York University, Team S8-G6, Turner Winter 2020 회원
YORK-TURNER-W20S8G6
5 회원들
안내서 21개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 486
