이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The hard drive is a storage device with 500 GB that can store data for a long time.
By following this guide you will be able to remove the Acer Aspire V5-473P-5602 hard drive in order to replace it or access other parts.
필요한 것
Flip the laptop over so the back panel is facing upwards.
Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
Remove the back panel from the laptop using an iFixit opening tool.
다른 한 분이 해당 안내서를 완성하였습니다.
