주요 콘텐츠로 건너뛰기
Acer Aspire V5-571 Cooling System Replacement
필요한 것
동영상 개요
  1. Acer Aspire V5-571 Cooling System Replacement, Keyboard: 1 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement, Keyboard: 1 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement, Keyboard: 1 단계, 이미지 3/3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Cooling System Replacement: 2 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement: 2 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement: 2 단계, 이미지 3/3
  3. Acer Aspire V5-571 Cooling System Replacement, Optical Drive: 3 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement, Optical Drive: 3 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement, Optical Drive: 3 단계, 이미지 3/3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Cooling System Replacement, Upper  Cover: 4 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement, Upper  Cover: 4 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement, Upper  Cover: 4 단계, 이미지 3/3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Cooling System Replacement: 5 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement: 5 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement: 5 단계, 이미지 3/3
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 Cooling System Replacement, HDD (Hard Disk Drive): 6 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement, HDD (Hard Disk Drive): 6 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement, HDD (Hard Disk Drive): 6 단계, 이미지 3/3
  7. Acer Aspire V5-571 Cooling System Replacement, Wi-Fi Half Mini PCIe card: 7 단계, 이미지 1/2 Acer Aspire V5-571 Cooling System Replacement, Wi-Fi Half Mini PCIe card: 7 단계, 이미지 2/2
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 Cooling System Replacement, Mother Board: 8 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement, Mother Board: 8 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement, Mother Board: 8 단계, 이미지 3/3
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 Cooling System Replacement: 9 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement: 9 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement: 9 단계, 이미지 3/3
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 Cooling System Replacement: 10 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement: 10 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement: 10 단계, 이미지 3/3
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 Cooling System Replacement, Cooling System and CPU Thermal Paste Replacement: 11 단계, 이미지 1/2 Acer Aspire V5-571 Cooling System Replacement, Cooling System and CPU Thermal Paste Replacement: 11 단계, 이미지 2/2
    • Disconnect the Fan cable.
    • Unscrew the screws that hold the Cooling system to the Mother board.
    • Carefully lift the Cooling system right up.
  12. Acer Aspire V5-571 Cooling System Replacement: 12 단계, 이미지 1/2 Acer Aspire V5-571 Cooling System Replacement: 12 단계, 이미지 2/2
    • Use a lint-free cloth to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Use again cloth with isopropyl alcohol to clean the Thermal surface.
    • Remove three Philips screws held the Fan shield.
  13. Acer Aspire V5-571 Cooling System Replacement: 13 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement: 13 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement: 13 단계, 이미지 3/3
    • Unstick the black tape that hold the Fan to the cooler.
    • Unlock the clip and open the Fan case.
    • Use a soft brush and clean the Fan and the Cooler
    • Close the Fan system.
  14. Acer Aspire V5-571 Cooling System Replacement: 14 단계, 이미지 1/3 Acer Aspire V5-571 Cooling System Replacement: 14 단계, 이미지 2/3 Acer Aspire V5-571 Cooling System Replacement: 14 단계, 이미지 3/3
    • Use the same technic to clean the surface of the processor from the old thermal compound
    • Be carefully,if you don't want to break the CPU.
    • Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
    • Did you do it successful?
결론
다른 4명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
192,056 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 한 개
Hello!
Is ist possible to installa SSD storage to the V5-571G without removing the SATA?
Thanks for your reply
lukasrohrer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 32
전체 시간: 9,236
