주요 콘텐츠로 건너뛰기
Acer Aspire V5-571 HDD SATA Cable Replacement
필요한 것
동영상 개요
  1. Acer Aspire V5-571 HDD SATA Cable Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 Acer Aspire V5-571 HDD SATA Cable Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 HDD SATA Cable Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire V5-571 HDD SATA Cable Replacement: 2 단계, 이미지 3개 중 3개
  3. Acer Aspire V5-571 HDD SATA Cable Replacement, Optical Drive: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement, Optical Drive: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-571 HDD SATA Cable Replacement, Optical Drive: 3 단계, 이미지 3개 중 3개
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 HDD SATA Cable Replacement, Upper  Cover: 4 단계, 이미지 3개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement, Upper  Cover: 4 단계, 이미지 3개 중 2개 Acer Aspire V5-571 HDD SATA Cable Replacement, Upper  Cover: 4 단계, 이미지 3개 중 3개
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 HDD SATA Cable Replacement: 5 단계, 이미지 3개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement: 5 단계, 이미지 3개 중 2개 Acer Aspire V5-571 HDD SATA Cable Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 HDD SATA Cable Replacement, HDD (Hard Disk Drive): 6 단계, 이미지 3개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement, HDD (Hard Disk Drive): 6 단계, 이미지 3개 중 2개 Acer Aspire V5-571 HDD SATA Cable Replacement, HDD (Hard Disk Drive): 6 단계, 이미지 3개 중 3개
  7. Acer Aspire V5-571 HDD SATA Cable Replacement, Wi-Fi Half Mini PCIe card: 7 단계, 이미지 2개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement, Wi-Fi Half Mini PCIe card: 7 단계, 이미지 2개 중 2개
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 HDD SATA Cable Replacement, Mother Board: 8 단계, 이미지 3개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement, Mother Board: 8 단계, 이미지 3개 중 2개 Acer Aspire V5-571 HDD SATA Cable Replacement, Mother Board: 8 단계, 이미지 3개 중 3개
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 HDD SATA Cable Replacement: 9 단계, 이미지 3개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement: 9 단계, 이미지 3개 중 2개 Acer Aspire V5-571 HDD SATA Cable Replacement: 9 단계, 이미지 3개 중 3개
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 HDD SATA Cable Replacement: 10 단계, 이미지 3개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement: 10 단계, 이미지 3개 중 2개 Acer Aspire V5-571 HDD SATA Cable Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully pick up the Mother board and disconnect the Battery cable.
  11. Acer Aspire V5-571 HDD SATA Cable Replacement, HDD SATA Cable: 11 단계, 이미지 2개 중 1개 Acer Aspire V5-571 HDD SATA Cable Replacement, HDD SATA Cable: 11 단계, 이미지 2개 중 2개
    • 13 pin SATA HDD Cable Adapter.
    • Did you do it successfully?
결론
작성자
1다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 4,860
