주요 콘텐츠로 건너뛰기
Acer Aspire V5-571 Optical Drive Replacement
필요한 것
동영상 개요
  1. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Optical Drive Replacement: 2 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Optical Drive Replacement: 2 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Optical Drive Replacement: 2 단계, 이미지 3개 중 3개
  3. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 3개 중 1개 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 3개 중 2개 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 3개 중 3개
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
194,093 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 2개
Is it safe to use with the optical drive out? I just took it out and I don't get the part until next week but I need to use my laptop... can I use it?
I needed to replace it because I dropped my laptop off the arm of the sofa with the drive open and falling on that side too.
Vianca - 답글
Is it safe to use the laptop with the optical drive out?
Vianca - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 16
전체 시간: 5,202
