주요 콘텐츠로 건너뛰기
Acer Aspire V5-571-6889 CPU Fan Replacement
필요한 것
  1. Acer Aspire V5-571-6889 CPU Fan Replacement, CPU Fan: 1 단계, 이미지 1/1
    • Unlock the battery by pushing the button to the right.
  2. Acer Aspire V5-571-6889 CPU Fan Replacement: 2 단계, 이미지 1/1
    • Unscrew the eighteen 8 mm Phillips #0 screws attached to the laptop.
  3. Acer Aspire V5-571-6889 CPU Fan Replacement: 3 단계, 이미지 1/1
    • Pry open the keyboard at the top of the keyboard.
  4. Acer Aspire V5-571-6889 CPU Fan Replacement: 4 단계, 이미지 1/1
    • Disconnect the keyboard label connected to the laptop.
  5. Acer Aspire V5-571-6889 CPU Fan Replacement: 5 단계, 이미지 1/1
    • Carefully pry open the keyboard frame.
  6. Acer Aspire V5-571-6889 CPU Fan Replacement: 6 단계, 이미지 1/1
    • Locate the Wi-Fi card.
  7. Acer Aspire V5-571-6889 CPU Fan Replacement: 7 단계, 이미지 1/1
    • Disconnect the two wires connected to the Wi-Fi card.
  8. Acer Aspire V5-571-6889 CPU Fan Replacement: 8 단계, 이미지 1/1
    • Unscrew the two 8mm Philips #0 screws attached to the Wi-Fi card.
  9. Acer Aspire V5-571-6889 CPU Fan Replacement: 9 단계, 이미지 1/1
    • Carefully remove the CPU fan.
결론
Joe Niu
회원 가입일: 09/20/17
628 평판
안내서 5개 작성하였습니다
University of North Texas, Team S5-G1, Thomas Fall 2017 University of North Texas, Team S5-G1, Thomas Fall 2017 회원
UNT-THOMAS-F17S5G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 708
