주요 콘텐츠로 건너뛰기
Acer Aspire V5-571-6889 Hard Drive Replacement
필요한 것
  1. Acer Aspire V5-571-6889 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Hard Drive Replacement, Remove Upper Cover: 5 단계, 이미지 1/1
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joe Niu
회원 가입일: 09/20/17
628 평판
안내서 5개 작성하였습니다
University of North Texas, Team S5-G1, Thomas Fall 2017 University of North Texas, Team S5-G1, Thomas Fall 2017 회원
UNT-THOMAS-F17S5G1
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 687
